Dun dun dun ...
Chevk587
Whiskey bent & Hell bound
California
E98BB200-B68E-428E-B656-B6219ECF937A.jpeg 1B420566-0710-4893-B9F0-FFCF8F64F929.jpeg So I just got a chance to climb under my rig after a trip to FORDYCE creek here in CA only to find I had cracked the frame where I did my four link conversion super bummed . Anyone else have this issue ... ?
any good fix ideas ?
My dumb question
Did it fly or torque it very significantly?
Well it’s awfully hard to say from that pic. Can’t really tell what happened. Need to figure out the cause to come up with a good repair
@Chevk587
This is the answer. Need to know cause, beyond the build and a possible stress riser. You will introduce more problems if the cause is not prevented
The plan at this point is a cross member and plate it both sides are the same in the same spot right next to weld .
Both side have bowed in to center of the vehicle .
Don’t forget to consider force from the front. It may have failed there because the link stopped it.
Also, if the frame is bowed inward, what did it do to that body mount?
I mean we’re talking a 1/4” ,the frame is also tied to the cage too
