We had an LB7 and ran it to 215,000 miles with all injectors replaced once and added a Kennedy diesel ECM. Great mileage, but injectors will need replaced every 100,000 miles or so and they are hard to access. We traded up to a 2007.5 with the LMM. We could only fetch about $7,000 for our LB7 and it had a good trans.
If you can find a 2007 - 2010 then you have the 6 speed and no particulate filter or can find a DPF delete kit for the 2007.5 to 2010; then you have more power, good mileage and 6 speed trans.
