I would have to look up the build sheet. My 383 had 350 rods, but with this block, the builder may have used 400 rods. He used Scat 9000 series rods and crank. Cam is Comp 270h magnum 224/224 @50 470 lift. Don't know the other specs of hand. TRW hyper pistons stick out of the cylinders by 0.005"
Quench should be 30-35 thousandths from combustion chamber to piston top. This head guy and my friend that has used his parts, said his engines require less advance than most due to the efficiency of his work. I don't have any proof one way or the other on that statement. You could be right about running less compression and more advance-I haven't heard much about one vs. the other.
I might still be able to run more centrifugal timing if I slow the rate of advance and/or limit the vac advance more. I think most people run less than 16 degrees on their vac advance for modified engines. I think I remember MSD stating that the dizzy I have is set for 10 degrees from the factory (I have a different can than what msd used-mine is adjustable too).
.030" quench?! Wow that is pushing it, your aren't trying to win the pro stock nationals or anything. My engine machinists actually moves it up to .045" on some larger engines because he says sometimes he gets contact with the head. Probably barely, but still, can't be good for the bearings. It seems like your engine builder is trying to build a record setting engine for a street truck, then uses a 30 year old single pattern cam design, a little odd. And with a piston .005 above the head, I get the same numbers as you, I did confirm your intake valve closing as well. 11:1 with a 9.1:1 dynamic is high compression for pump gas, especially with old combustion chambers, a small cam, and a carb. I would of never went that high. So unless your pistons are a dish and not a flat top, I would be using E85 or race gas or something with that thing.
