Dynamic efi ebl
chosen(1)
Michigan
Right now I have a mild 383 running on a mostly stock tbi setup, and while it runs ok it should run much better. I was thinking of going to the ebl setup, but I'm having a hard time figuring out everything I am going to need to set it up and get it tuned. What I need is someone to give me a complete list of everything I need to get running and tuning with an ebl setup.
A search here and at thirdgen.org will tell you lots of stuff about it but basically, (the way I did it) you need the EBL board, a laptop with a .bin editing programme and if you want to make life and tuning real easy, a wideband controller(I used ZT" by zeitronics), IAT sensor, Ostrich emulator (saves burning loads of chips and can be loaded whilst out driving. That's about it unless I've overlooked something. Thirdgen has pages on the 'tuning with EBL' thread under the diy prom board.
Big91RustyBucket said:
What do you wind up spending on such a setup?
Their website has their prices, then you'll need a WB controller (but not essential), see Zeitronics site for that (I bought mine over here in £s) and an IAT sensor which is only a few bucks. And obviously, a laptop.
