argh... and the 3/4 ton is the semi float....argh....is it possible to make the 3/4 a 1 ton? if i had 2 axles, and put all the 1 ton stuff in the little one?
3/4 and 1 ton 14 bolts with 10.5 inch ring gear are all full floater. They are identical with the exception of the spring perch width. The semi floater is a 9.5 inch ring gear.
