e-brake help
K5Greek
Vineland, NJ
when i swapped in the 14b, the lines for the ebrake were too short so i dont have them connected.. what do i have to do to get these to work?
How much lift you have? Maybe lower the L brackets on the frame some?? I thnk if your not careful when you flex it can pull on the cable applying the e brake.
I searched forever on the same thing, after I did the swap of course. When I get all the other things done on the list of priorities, I am going to do something homebrew. Not much help I know, but at least you aren't the only one dealing with it.
