Got a stupid question about my e brake. This entire setup is kinda screwed up as Im puttin 84 up style cables into a 76 or so 14 ff. Anyways I got the cables attached to the drums and run to the equalizer bracket (the kinda triangle looking thing with two holes in the back and one in the front). The pass. side threaded rod is run through one of the back holes, and the driver side clipped into the other. Then just the actual wire cable continues through the bracket, through the front hole and connects with the front cable that is attached to the pedal.
So when I push the pedal down the front cable pulls the drivers side cable and tightens the drivers e brake only. I dont see how this setup works, the equalizer bracket dosent move to pull the pass cable. It seems that the bracket would need to be some how attached to the cable itself, not the shealthing.
What am I missing?
Hope this wasnt to long and confusing.
Rebil
What am I missing?
Rebil
