E brake
cegusman
3/4 ton status
Houston/Katy, Tx
I just put a 4" rough country lift on my k5, and swaped in a 14 bolt ff, The e brake cable is to short. What does everyone use to solve this problem.
Houston, TX
What part of houston do you live in. I live in tomball tx it is a small town in north houston.
"When you say i drive a fullsize are you calling my wife fat."
J/K i was bored and made that up i don't even have wife i'am only 17.
I just have a 10-bolt, but with my 4" RC spring lift my e-brake cable was interfering with my springs when trying to go under it as factory setup was. I simply re-routed mine to go through the spring. That little extra bit helped me.
You should also have an adjuster in the middle of it right about the middle of the cab or so. Have you tried letting out the salck there first?
Brian
Check out <a target="_blank" href=http://tx85gmcguy.alloffroad.com>My Jimmy</a> with all her projects!
