Hi Harry,
Sorry, I don't have pics but it is really not too rough. The main cable comes from the front of the vehicle and terminates with a long screw. Attached to the very end is a spring which attches to a tab on the underside of the 'bed'. A piece of metal 'folded' to make a channel slides on the threaded portion of the end of the main cable and is adjusted by a nut that threads onto the threaded portion of the main cable. Through this channel is another piece of cable about oh...30" long. To both ends of this piece of cable, the cables from your brake drums are connected via a kind of 'C' shaped piece of metal. Now, additional springs are used to hold the whole assembly up and away from the driveshaft/transfer case output area. With a body and suspension lift, I fiddled with the placement of mine to ensure that a limp dangling cable would not wrap around the driveline.
Sorry for the criptic description. Hope it points you in the right direction.
