Easiest way to center steering with bent style drag link?
Mastiff
Tucson, AZ
I'm trying to get it perfect, but can't rotate the bent drag link all the way around due to interference with the crossmember. If I articulate the suspension like crazy I could get it to rotate I think, but the steering is crazy by then, so it's hard to know how far to adjust. Is there something I'm not thinking of? If it involves repeatedly removing the link ends, I'll just live with it. :deal:
Turn hard left, see if it turns there. That's what mine does, it's the ORD unit
That worked like a charm! Thanks. It still took two tries since you can't actually center it while making the turns, but so much easier than where I was headed. You can only get to within one full turn anyway, without removing the ends.
