easy stuff.....
hi pinion
3/4 ton status
**PLUMBING THE WORLD**
what would cause my truck to die?????? i know for one the batt is shot, but i can charge it up enough to get the truck to run for a while ,go down the road.Its like when i press the gas , the truck runs fine, but when i come to a stop, it wants to die. Could a bad batt be causing this??? or does it sound like the alt?? Btw i dont want to risk taking the truck to auto zone,should i take the batt and the alt down there?? have them both ckecked?? Duuu..... /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif or just the alt??
[ QUOTE ]
[/ QUOTE ]
Then buy a new one You cheap fawker /forums/images/graemlins/rolleyes.gif
/forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
i thought i could save money by just repeatedly charging it /forums/images/graemlins/dunno.gif /forums/images/graemlins/histerical.gif
you can ask if they got any used batt. for sale
sometimes they do down here and there only like15$ abatt i think
ill do just that/forums/images/graemlins/thumb.gif but could the batt be causing it to just cut out like that????? /forums/images/graemlins/confused.gif /forums/images/graemlins/thumb.gif
it could
iknow if you take off the power cable while runnin it will die and ive had a bat. so dead it killed my truck everytime i turned on the head lights
[ QUOTE ]
it could
[/ QUOTE ] i was told just the opposite, i was told you should be able to remove the cables and the truck should still run /forums/images/graemlins/thinking.gif
[ QUOTE ]
[ QUOTE ]
it could
[/ QUOTE ]
Maybe, but you'll fry the alternator in the process, and it'll die shortly thereafter.
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
it could
[/ QUOTE ]
[/ QUOTE ]
You should be able to pull the positive cable off and the engine will keep running. If your alt is bad it will die.
I have had a problem similar to this his before, if when you come to a stop and keep enough pressure on the gas will it stay running?
If so you could have a bad fuel filter.
I dont know if the battery could cause that,but with EFI maybe they are more sensitive to low voltage than a carbed rig--it might be the fuel has some water in it,around here this time of year the gas stations are switching to the "winter blend"of gas,and I've noticed both some water in my gas I've bought for my mower in the gas can(and I know it wasnt already in there!)and also noticed my rucks have started "pinging"after a fill up there.I put some Shell higher octane gas in one and it stopped pinging,without touching the timing or anything else.My other truck doesnt get used often,so it has a pretty good water build up in the tank--I have to let it warm up for 10 minites before it will pull away without wanting to crap out,and have to hold the gas pedal at fast idle to keep it running at stop signs--adding 4 bottles of isopropanol dry gas made a huge difference in the way it ran--maybe you should do a "piss test" on your gas,and see if its got any water in it,or just toss in a few bottles of dry gas(use only isopropanol in EFI)and see if its any better.. /forums/images/graemlins/thinking.gif
[ QUOTE ]
[/ QUOTE ]
And if it's not bad, this is a very good way to MAKE it bad.
Check output with a multimeter. Why anyone would test any other way is beyond me. Not having a multimeter is not an excuse.
its completely amazing the severe symtoms the blazer through out on just a dead batt........now i put a new one in and it runs killer. /forums/images/graemlins/peace.gif and for those of you who diddnt know,dyeager is the man /forums/images/graemlins/peace.gif its amazing how stumped everyone was on just a DEAD BATTERY!!!! Bwahahaa /forums/images/graemlins/histerical.gif wake up guys /forums/images/graemlins/histerical.gif /forums/images/graemlins/thumb.gif
JUST for the record, this little pulling off the battery cables while running fix(wich i diddnt do)was told if you have a computer it can DESTROY the computer completely, among other things,(suprizingly i was told this by the kragen guy lol)......so dont do it!!! YOUL ^%$#$ YOUR TRUCK UP DOING THAT!!! /forums/images/graemlins/thumb.gif
It's not EFI, his is an 85 and is still carbed.
Good to hear it is running again Jake.
STFU /forums/images/graemlins/deal.gif /forums/images/graemlins/histerical.gif Yeah its running bitch!!! i got the heavy duty trans too , its only a matter of time before i unleash the picks /forums/images/graemlins/peace.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif BTW these things break down so much, id be better off with a horse and buggy /forums/images/graemlins/thinking.gif /forums/images/graemlins/histerical.gif
