Ok so i searched first... but i was having a problem after putting the new hose and master on..i had no pedal.... well i gravity blead it (father recommended and he is a mechanic) when i told him that didnt work he laughed and said.. yeah they are a biatch!!!... he said usually that is all you need to do.. he said just pump it up a mess of times, let it sit, pump more and let sit.. keep on doing it..
i figured out an easier way... so in the future.. i will gravity bleed it...
then remove piston from bell... put piston down and bleeder aiming up... and push piston in and out... few times.... then put back in.. I have a GREAT clutch... even moved the truck first time in 2.5 years... got rubber marks in the street and my driveway.... so IT IS ALIVE!!!!!!!!!!!!!
