Eaton H052 or H072 rear in NJ NY PA area
I got an HO52 with No-Spin under my 70 Suburban. I believe it's 4:10 since it's an auto truck, but could be 4:56 since there is nothing on the SPID other than No-Spin. If you want the whole axle I would need to find something to replace it with though. It also has a skid plate over the center section, not sure if it is Home made or factory, but it is bolt on.
Let me know and make me an offer. You'd have to pick it up, and if you are in a hurry, you'd need to come help remove/replace it since I am not planning to remove the axles til most of the rest of the truck is parted. truck is in 13901.
Im interested...and in no big hurry.
Dont have a complete axle to replace it with though. I might have a 14 bolt housing you can use to roll it around.
Pics??
Here is a picture of it:
Those are the best I have right now.
As for an axle, I just need it to roll. I have a pair of 6 lug rims and those 8 lug on it, so either would work. Ofcourse, if you don't need it til I am mostly done parting it, that might not be an issue.
ok, will do. It is listed as a No-Spin rear on the SPID and I have no reason to believe that it was ever changed. Not sure on the ratio, but it is an auto, so it might be 4:10's
Will let you know when I find more out.
