Eaton HO72 Yoke Needed. 14bolt swap?
OrangeCrushK10
Square State + Suspension Item
I need a new Eaton HO72 (rear 3/4ton or 1ton axles, 72&older) pinion yoke since mine's all busted up. Does somebody have one or does anybody know if I can swap a 14-bolt's yoke into it without changing anything else?
Thanks!
the 14 bolt's will not work. Jess at High angle driveline had a 1410 yoke custom made for a guy with an Eaton on the pbb, and I dont think it was too expensive.
