Anyone familiar with this ECM setup? Thinking about swapping my OE ECM out for one of their modded ones to play with the tuning of the little LO3.
That's where I saw it. And I'm on the gearheadefi forum too but some fellas here have a lot of expertise and this forum is more active most time.I haven't used it, but EBL has been around for a long time now. I wouldn't be hesitant to use it.
If no one here has more feedback, you might find a bit more posts on it over at thirdgen.org's forums. I know I heard about it long ago there.
Anyone familiar with this ECM setup? Thinking about swapping my OE ECM out for one of their modded ones to play with running off the little LO3.
Yeah. Screaming 170hp.I feel like this came up recently.
Don't have any personal experience, but how can i push you towards it?! still something i am mildly interested in. I would probably buy one if i had a bunch more 400 dollar bills burning holes in my wallet.
whats the LO3 again? 5 liter TBI?
I don't have any desire to really change EFI systems. I just want to be able to tune it, and like you said, this is kind of a one-and-done when it comes to the "work". The rest is just driving and tinkering as opposed to continually pulling the ECM and prom.It's a fair bit of an outlay for cash for sure, but if I were to check what it costs to be able to catalog and burn chips efficiently now for TBI, I wouldnt be surprised if they are near the same.
What I found interesting is that it's nearly the same cost to have them do the work to your ECM, as it is to DIY.
Im tempted to go this route as I plan to use the underhood ECM on a couple of projects, and chip burning and swapping does get tedious. Plus last I had checked, the chips used for burning for some applications were no longer made, and fakes had started to show up in the market.
I don't expect 300hp from it. But I think some mild mods and good tuning can get me near 200.Hey, if you have the money and just want to, no one can fault you for that!
I think the 305's may not have the margin for improvement 350's the same vintage have, assuming the LO3 was "high" compression compared to the 350's of the same era.
But the theories are all going to be the same...fuel, timing, load, etc. What is done with a 305 will be done with another engine, just different numbers.
And I can always just toss my OEM ECM back in if it goes sideways.
I think the factory heads will support nearly 300hp with a little port clean-up but that's farther than I want to go. If I have to pull the heads, I'll look for a set of the TPI 305 heads or the L30 Vortec heads.I know there are a few articles out there about making power with the 305. It could certainly be fun to squeeze out some more power. My suspicion is that heads would be required, but I guess depending on how crazy you wanted to get, that wouldn't be out of the question.
Hell, with EBL IIRC you can boost it too. Maybe that could be a fun experiment?
