ebuy of the day
Other than the uber big blocks and the lowered rear spring hanger its a preety decently built rig. I cant really say anything bad about it.
edit: some of the welds around the t case look sketchy
In case yall were wondering...those kinda things are the norm around here...:eek1: :doah:
In their defense...(im gonna get burned for this) these trucks are trailered to the local mudholes...and theyre not used for anything else.
THat being said...wonder where in orlando its at...
Ford steering wheel cover!!!!!!!!!!!!!!!!!!!!!!!!!1111
Looks like it should be parked at Checkers/Rally's
ummm but it says its never been in the mud and it had to get in the parking lot somehow :thinking:
I like it. Not exactly how I would build it but I like it regardless.
How tall are those tires?
Theres no plate on it either. I doubght thats street driven.
I bet it was trailered there for something, or its at a shop.
theyre michelin xl's i believe something like 52". I know im close but not 100%
The point of my post was that all of the "big guys" in the area are building theyre trucks liek htis HUGE springs, hanger drop downs. Or drop down hangers and huge blocks:eek1: ....
Remember the white f150 on rocks that was posted here a while back? Guess where that was from? Yeeap Here in florida.:doah:
Yep a bunch of people with huge ass tractor tires, rock wells and lots of booty fab experience.
Some are built pretty decent but still retardly big.
Trucksgonewild.com
those are not blocks. they are basically raised leaf spring mounts and they are welded to the housing. kert makes some similar to for 14bolts but I bet he will say use for rear only. they are welded to the top and down the front and back sides of the housing, a lot of guys do that so they can just use off the shelf 12'' springs. spray that truck with some OD green and mud the piss out of it.
it actually looks pretty well built, typical florida mud truck though. I bet hes got $5k in just the axles, front axle housing shortened and the taper taken out, instead of just flipping the hubs, detroits, instead of welding the diffs. wheel mounted disc brakes, instead of pinion brakes. looks exactly like something out of the chucks trucks shop, in there other ebay auction it looks like chucks shop in the background.
Dustin
