If the truck came with an ECM, then it's a California model with the CCC (electronic control of carb primary needles). If that was unplugged, it's unlikely the thing would run right. More likely, is that your truck came with a 305 and the ESC system. That box above your glove box plugs into the distributor and retards timing if the knock sensors ring. It can be bypassed. TCC lockup was not controlled by a computer until the TBI system came out ~1987. If you keep the factory vacuum switch and brake pedal switch, the transmission should continue to lock normally, but the sniper may give you the option of electronic control, if desired. Without knowing any more, it's hard to predict if that could work any better.
