ECM Mount / Bracket
doubletrouble
Milliken, Colorado
Any body know where to get the bracket / mount that the factory ecm bolts to? I am switching from carb to TPI and need to mount the ecm. It is the same as the early 90's camaro's. I'm to lazy to go out in the cold to look at the salvage yards. It has two slots on each end and two on one side that the bolts on the mount slide into. Thanks
ragged on ebay sells them...
You can do just about anything with the ECM like cable ties and velcro. Just don't let it get wet.
fyi if you have a 80/s truck and its got esc = electronic spark control it will have this behind the glove box already.
easy way to tell esc is extra 4 wire plug off distributor
I made my own ECM Mount / Bracket. It cost me almost $5.00 in materials.:smile1: The rubber isolation mounts were the expensive parts.:eek1: If you look close at the first pic, you can see a center to center measurement of 6.625", the other side measures 6.750". I sure like having a set of calipers when I fab something up.:D
dave w
