ECU swap when changing from 700R4 to 4L80e
Dezertracer
Registered Member
SoCal
Does anyone have experience swapping a 350 TBI/4L80e ECU and wire harness (91 Suburban 2500) into a 350 TBI/700R4 (89 Blazer) with a 4L80e transmission swap? Seems like a cost-effective alternative to a standalone controller for the electronically shifted transmission.
What is a good source for the schematics and ECU pinouts on a 91 Suburban 2500 ECU?
The mechanical to electric speedo conversion will be an additional issue.
I'm going through something similar (th400 to 4l80e) and I ended up just getting the TCI standalone controller. Keep your existing ecu for the engine and you'll need to splice a few wires for the standalone.
Problem with trying to use factory is that you'll run into compatibility issues through the various iterations of 4l80e unless you get the harness, ecu/tcm, and transmission from the same vehicle.
If you have the complete harness that came with the 4l80e I would use that.
