RubberFloorMat
I know that some will simply say put a holley on it but id like to tune my 1406 up a bit, I have a mild off idle hesitation and a bit of a exhaust gurgle/thump during light throttle (45 mph)cruise. Im reading that the 1406 is set lean from the factory and one of the first things im going to do is put a step spring on then do metering rods etc. It pulls nice through the gears but really only cleans up at the higher rpms, above 2800 or so.
Anyone messed with these at all? its on a newer gm goodwrench 350 with Edelbrock intake and unknown spec small RV type cam. everything is good ignition wise and im sitting at 14' timing.
Input?
Input?
