Edelbrock MPFI or Holley 670 CFM TBI
I can't give a compairson, but can tell you that I am running the Edlebrock MPFI on my 383. It took Edlebrock a couple of trys on the chip to get it right because they didn't list their system for a 383 when it was built. The system has run flawlessly, no matter the angle, bouncing etc., and has produced 15mpg on the hwy w/38's and 5.13's. The system has work well for me.
Derf00, Have you dynoed your setup with the MPFI? Could you share some of the specs on your engine? Are you running the 19 psi injectors with the MPFI?
I didn't dyno my engine, to cheap to spend the extra bucks. The engine was built by Sunset Racecraft of Lubbock, Texas. The crank and rotating assembly is Scat, Vortec heads, LT1 roller cam, Edlebrock MPFI, and Edlebrock Headers. The cam is computer friendly and it should pass emmissions if required.
Sunset rated the engine at 350 HP, & 425 fp/lbs torque. If you want more info, let me know.
