So my carb decided it wants to start acting up.
First i thought it was ign related, because it happened when hot. Then i realized it wasnt happening because it was hot. but rather on my way to work is all freeway untill i get close then there are a few lights i need to stop at for a while.
Basically if i idle for a while my truck will start loading up with fuel. Runs kinda wierd e.g. idle changes. Then when i go to take off it bogs and misses for a few seconds untill it clears out, then it runs great agian. If i only idle for a few seconds it is fine, but any longer than that is when i have the issue.
So tommorow after work im gonna pull the carb out and give it a good cleaning. Thinking this will fix it. Anything in perticular i should look for? Ive had numerous Dirt bike carbs apart, and a pair of Mikuni 44phh's that i had on my datsun... But ive never delt with a plain ole 4 barrel carb.
