Depends on what you're buying intake and distributor wise.Its same or less than the others once you factor distributor and intake
Go cheap non Vortec stuffDepends on what you're buying intake and distributor wise.
Cheapest open plenum is $200 just to compare apples to applesYou can get a sbc Edelbrock aluminum intake for under $150. Or I just got one for $42 shipped from my friendly neighborhood CK5er.
Distributor like mine was $400. However, now you can get one for the Sniper specifically for $238 https://www.summitracing.com/parts/sne-565-300/make/chevrolet
Like I said, depends on what you buy.
So whats the big advantage?I'm still in the process of finalizing all the details on my ProFlo 4 setup but so far I like the Edelbrock MPFI. I had to screw with the linkage bracket and drill another hole. The throttle body is cast and not billet like previous systems I've seen before. The wiring harness is well made, the instructions are simple. The injectors look to be LS2 shorter style. LS1 and LT1 are longer and won't fit. The ECU is not designed to handle any boost but I wonder if a custom tune could be done if you ever wanted to. It does not control the transmission like others like Haltech can. The intake manifold is ok. My single plane Procomp EFI manifold seemed to slightly larger on the ports. Its hard to beat the price when you want a plug and play system that will work with most engines and has the all the features. I did not get the tablet since I have a couple Samsung Note phones and something smaller might be easier to fit on the dash. The gauge layout looks nice to have on the phone while driving and have it be dedicated to the vehicle to monitor vitals. You can download the app for free if you want to play around with the software and there's a demo mode. Looking forward to getting the engine started.
Few videos out there like this one that shows some details
I think if I had to buy it again, I might opt for the other system which is the same price. It has a higher flowing throttle body and I read this intake flows pretty well.
MehSimplicity, works with high hp engines, easy tuning, cost factor when you compare other setups with semi tunable ECU.
Granted you can probably buy a used LS setup for the same amount.
The problem with a used 5.3 is you never know what yu are getting. Most 5.3s around here in Phoenix are beat to crap and already have lifter and bottom end knocks. There is a guy in Nevada IIRC thats sells guaranteed X amount low mileage 5.3 with turn key harness for your setup but you pay like 4K. Im just keeping with my low mileage 350 and redoing the top end with heads, cam and fuel system. The Pro-Flo is MPFI but not sequential so its a batch firing system like the old Tune Port Injection systems were. Still... far better than the TBI from the grunge age!
Agree on the used LS engines. I've had enough problems. I've seen 6.0 engines go for around 1000 to 1500 but usually high or unknown mileage.
This shows it be sequential, not batch.
quote- Edelbrock has released their latest generation of fully sequential port self-learning electronic fuel injection... Pro-Flo 4 EFI!
https://www.jegs.com/p/Edelbrock/Edelbrock-Pro-Flo-4-EFI-Systems/3649794/10002/-1
https://www.jegs.com/webapp/wcs/sto...&submodel=&engine=&Nrpp=&No=&persistYmm=falsehuh... well that is one of the questions I asked Edelbrock when I sent them an email. it was a little muddy on descriptions. Even the instructions are different with the one in the link talking about the Hall effect sensors but the basic $1600 units not even showing a hall effect sensor int he distributor.
It would be nice if they are ALL in fact SMPFI. Hopefully I am worng and they all are.
I think thats an older system they use to offer and still do.Here is the the one sequential they offer.
https://www.summitracing.com/parts/edl-35000/overview/make/chevrolet
It uses a different distributor and inside of it is a hall effect and shutter wheel for FI firing.
ALL Pro-Flo 4 systems are in fact Sequential.
