ladybugblazer
Registered Member
I've had this problem ever since I got the truck it seems like the throttle doesn't fully reset after I hit the gas. I have to open the hood and manually bring it back and it shifts just a tad, but that slight shift brings back idle down from ~1000 to 600-700 rpm. Carb seems to be an oldschool weber edelbrock 1405 except with electrical choke. I tried to spray where it links together with carb cleaner and then lubricate with 3M but that didn't help. I attached a picture of what the setup looks like. Maybe its gummed up on the inside of the carb? What do you guys think...
Below the pink arrows is what I bring back ever so slightly and it smoothes out idle. It just never seems to be able to get back to this position on its own
