utherjorge
So, I decided NOT to light the Blazer on fire and walk away. Yayyyyyy.....
I pulled the alternator off and got it tested. The machine couldn't even run the test...fried.
The one I just took off is a 94-amp with a 2-pin connector. I don't think I should attempt changing something to a 4-pin with my level of expertise...or lack thereof.
Are there any other options with a serpentine pulley that go for more than 94 amps that you guys know of?
