C
crashyyz
Guest
hey all.. i'm the new guy (been lurking awhile). not just new to the site .. new to diesel engines also. this is my first. it's a 84 K5 Blazer with the 6.2L
there are some weird routings and hoses running around the bay of this engine and although I see a routing diagram on the rad support.. it really doesn't tell me where they should go. specifially, there's the hose that runs from the oil fil tube, to something called a crankcase depression regulator valve. now, based on the crude diagram, it seems there are supposed to be two hoses running off of that. one heading somewhere to the left (drivers side) of the engine and one to the right (pass side) of the engine. mine has obviously been messed with, as i only have one hose coming out of the bottom of said valve and it runs over to the pass side and simply is dumped down by the front diff.
can anyone tell me where it's supposed to go. it obviously doesn't help with fumes inside the truck while driving (i've only had it on the road one day)
thanks
crash
thanks
crash
