Connor strom
Registered Member
- Joined
- Feb 18, 2016
- Posts
- 42
- Reaction score
- 2
Im hooking up an egr for emissions testing and have a question for the vacuum lines to make sure im doing it right. Now from my under standing i can run the lines as so...from egr into a thermal ported vacuum switch hooked into a temp senser port on the intake (next to thermo housing) and from there i can run it straight into the carb. My thinking is that the vacuum is pulled from the carb into the switch and when the switch opens it allowes vacuum flow to the egr allowing it to open and what not? Would this work or am i missing something
