EGR removal ?
digity
Brentwood Ca
Trying remove egr. Two nuts and as easy as that. However, I can't remove egr cause theres a rectangular shape thing on a bracket in the way. I'm assuming some kind of sensor or another. It appears to to have a couple clips that would release it but not working. Thought maybe someone would have some know how b4 i force it n brk it. Oh yes its a 90 jimmy stock 350 EFI:doah:
First, I hope you're replacing it. Removing it permanently is illegal. If it's gone when you have a smog inspection, you won't pass. That said, you might try looking at one of the DIY books like Haynes, etc. If nothing else, try the on-line LMC catalogue has some nice blow ups of things that may show it.
I'm guessing it's the EGR solenoid. Two vacuum lines, two wire plug? Probably need to unbolt it, unless you don't mind the bracket sitting there.
