Egr valve issue
Supervillainmc
Registered Member
New York City
I put in a new Egr valve. I been driving it for years without it it with no problems except the check engine light would go on and off. I had it disconnected and plugged . After I put in the new one and connected it it drove fine for about 30 min then at stop sigh or light it would start bogging. When driving it would be fine till I slowed down or stopped. It didn't stall but sounded like it would. Did anybody have any similar issues or know what it could be? I would really appreciate any help.. Thank U
Did you get the factory GM EGR replacement? People have reported sporadic success with the generic aftermarket replacements that are supposed to fit everything. Seems GM was pretty precise in which valves were used with which applications.
That is interesting. I want to get a new EGR for my new engine, and I was going to get a cheap Chinese one for $35, but after your post I am re-thinking that. I found a Delphi one that is an OEM replacement, but they are $100.
I honestly can't speak as to what is different, either. If I've got my terminology right, there are two main categories, positive and negative backpressure (apparently relating to relying on vacuum or exhaust backpressure to open them up or feed EGR to the engine) but beyond that GM used a host of part numbers. You'll see the aftermarket ones listing 3+ GM numbers they replaced, and GM did not just randomly reassign part numbers. Probably akin to the vacuum pots on the Q-jets, would not be surprised if they had to be different based on the vacuum the particular engine pulled under X operating conditions, and probably a particular diameter orifice on the vacuum fitting, among other things like GVWR, axle ratio, etc.
It's pretty hard to stomach the cost of the OEM EGR valves, but at the same time, it would suck to spend $35 and have a problem remain, or change due to an incorrect EGR, which would be near impossible to know if it was the issue. And while probably often not done for any legitimate reason, cost of replacement IMO is certainly one reason to eliminate EGR. Of course, eliminating it with a carb or TBI presents their own difficulties.
For the OP, disconnect the EGR solenoid, or the vacuum hose (and plug it) and see if the problem goes away. Should trigger a CEL, but will not affect the engines performance with the light on. If the problem is gone with the valve disconnected, there is something wrong in the EGR circuit...check the hoses for condition and routing...about the only thing that could cause an issue with it running other than the valve itself. Pretty tough for the electrical side of that circuit to work just enough to screw up how it runs.
There are still some original GM EGRs but you almost have to ask the seller if it says "Made In USA" or not. The ones that are "Made In China" come in the same box as the original GM EGRs with the same GM number.
No.Not a Ac/Delco. I got it on EBay for $25. It said it was the aftermarket equivalent . It runs fine for about 20-30 min till u get to a stop sign or red light then it stRts bogging so that I have to give it has and brake or it will stalk. I let it idle and it keeps stumbling. When I drive off its fine. Strange. Could it be a Egr solenoid problem? I would think of it was the Egr valve itself I would have stumbling from the get go. Any help will be greatly appreciated
If you do more research you'll find that the EGR and solenoid can give you a lot of different issues when they start going bad. Anything from stumbling off the line to stumbling on a cruise. Sometimes it will boggle down so bad that it almost dies. Some of the symptoms can lead you to believe it might be the coil on the distributor.
Best way to find out is to remove the EGR and solenoid from the system and see if it improves or not. As stated, you'll get the SES light but it won't hurt the system.
Thank U
