Yeah, that would help me out alot. I am trying to take a trip to the river this weekend in the K5 and I want it to be running well for the 2.5 hour trip
(1) Check vacuum source to EGR solenoid (if not ok, repair)
Ignition "OFF"
Disconnect EGR solenoid vacuum harness (hose)
Install hand held vacuum pump on manifold side of solenoid.
Apply vacuum. (does the solenoid hold vacuum?)
If yes
(2) Ignition "ON" engine stopped.
Does vacuum drop?
If no
(3) Ground diagnostic test terminal.
Does vacuum drop?
If yes
(4) Remove ground from diagnostic test terminal
Ignition "OFF"
Connect a vacuum pump to EGR side of vacuum harness (EGR side of solenoid)
Using a mirror, observe EGR diaphram while applying vacuum
Diaphram should move freely and hold vacuum for at least 20 seconds.
If Ok
(5) Apply vacuum to EGR valve.
Start engine and immediately observe vacuum and valve position.
Valve is good if valve moves to seated position (valve closed) and vacuum dropped while starting engine.
If Ok
(6) A/T (auto trans) check P/N switch (park nuetral saftey switch)
If Ok no trouble found.
If any of this shows different than what i just described then let me know and i'll post the NO's and what to check for.
