Who knows about them and how to properly test a positive back pressure EGR valve? I have searched and found some info but it is contradicting with other info.
Here's what i know from my testing tonight. I first removed the vacuum hose from the EGR valve (EGR still attched to the engine) and hooked up my vacuum pump and when i pumped it i could see that the valve opened (from everything i've read and have been told this should not be able to do be done with this style of valve), i then pulled the EGR solenoid and tested that it's working by hooking a 9 volt battery across the terminals and the solenoid clicks and i'm able to draw a vacuum through the solenoid, i then started the engine and once again hooked my vacuum pump to the EGR valve but now with the engine running the EGR valve will not open when i try to apply a vacuum to it. With the engine running i was able to manually push the diaphram up and the RPM's changed by about 100 RPM's which tells me that ALL passages are clear. The only thing i don't know now is if i'm getting a reference signal to the EGR solenoid when it is commanded to open (how can i test for this)? Also because of my initial test of applying vacuum to the valve (still attached to the engine) and the valve being able to open do i even have the correct valve? I did replace this valve once by vehicle specific application several years ago.
I may not even have a problem but i want to make sure the system is working properly since my NOx was slightly higher than the MAX allowable for emissions testing purposes. If the EGR system is working properly then i need to install a new CAT ($225.00 installed) no more friendly $99.00 Hi-Flow CATS in California.
