Eldorado caliper price?
4wheelattitude said:
It may sound expensive to you but I paid $174 for a remanned set fully loded (spings, bolts, brackets and pads) for $174 to my door. I thought about it a while and decided that wasn't bad. Most places want $300 for a rebuilt set + core. Think it over. For the effort of putting something else together or taking a chance on used, I think I saved alot of time and trouble. The guy from eBay said he only had one set left. Good luck!
NOW...when you say "set" do you mean BOTH calipers? :confused:
and another thing,,,i have a set i bought off of Ebay awhile back, but the problem, is the bolt mounting holes are too close together, they would bolt up in the same location that my stock front calipers bolted into,,,,anybody know whats up with that?
didn't mean to hijack, but just adding alittle more info perhaps and possibly answering a question i have as well. :doah:
Whatever you think you need to do. You can also use a manual line lock that is basically an inline valve that holds pressure to the caliper. If the state knows that much between Ebrakes than that sucks.
Heck in Texas (with a manual) you can just put it in 4th gear and make the truck jump and pass the ebrake test.
In NJ, they drive your vehicle thru, you just stand there in a waiting room.
HarryH3 said:
The "E" in e-brake stands for "emergency". If you lose hydraulic pressure then the mechanical e-brake can save your life. Brake lines do fail occasionally. I've also seen them get caught on rocks, branches, steering parts, etc. and rip apart, or rub against a tire and get holed. That's the reason that most states require a mechanical backup system. A line lock doesn't meet that spec.
If you lose hydraulics, you will be very lucky to stop using the "E-brake". You're better off having a manual transmission at that point. This is the reason they are no longer called E-brakes, but "Parking brakes". The intention is to hold the vehicle from rolling away by purely mechanical means.
HarryH3 is dead on the money with his reply. :thumb: If you lose hydraulics, and you have a mechanical ebrake, then you still have SOMETHING to try to stop. If you only have a line lock, then you have nothing to try to stop with. :rolleyes: I believe car manufacturers must have two different brakes systems on their cars [like hydro/mech] in case of brake failure. The ebake does not stop as good as your primary brake system, but it is still better than nothing. The transmission is a whole different discussion, this thread is about ebrake calipers.
If your e-brake won't lock the rear wheels, then you need to get your brakes fixed. :eek1: :rolleyes:
I'm not saying that there's no way to stop a vehicle with a parking brake. I'm just saying that is not the intent of the vehicle manufacturer. That's why it's called a parking brake and why the controls are specifically designed to make braking the vehicle difficult. The old hand levers were nice, all you had to do is keep the button depressed. These push to set, push to release deals are like death traps if you're trying to stop your car. And if you're using it, you probably have an urgent reason! The pedal to set, handle to release isn't much better.
It's very easy to lock up the rear end using the parking brake while driving and if you also can't get it released right away, you are looking at an effective laxative. :eek1:
I talked to eBay seller yesterday and he stated he had another set to put on the auction but hasn't got around to it. The sellers user name is roanokedunn. feedback 377 and 100% . Here is the auction number when I purchased 8005095172
Harry
Have you used them yet? All the same brackets work for non ebrake calipers and the rotors are the same right? (I forget). I have been wanting to do discs in the rear, but really want an e brake (driveline e brake was no good). I think I might buy his other set.....
They changed the names, when more woman started driving, The big 3 changed the name of things that had an unsafe sounding name!!!
It Is not truly called a parking brake!!! It Is called a E-Brake, E for "Emergence" Its A law you must have one "For Emergencies" How many things can you think of that have new names, Firewall and Hazards, rollbar!!! :D :D
