No, its fairly simple. Just remember to have the power come from the ignition switch, so if you forget and leave it on, it won't run your battery down.
Look at your choke cap. If there are two terminals, then one goes to ground, and you put 12 volts to the other to OPEN the choke.
If there is only one terminal, then you put the 12 volts to that one.
Remember, you leave the switch off when its cold, then when the engine starts, turn the switch on and leave it on.
As for the manual option, they make a kit. Fairly cheap. In fact, usually a little too cheap.
If you get one, buy a heavier duty control cable. It replaces the choke cap. You press the accelerator down slightly, pull out the choke knob.
That closes the choke and puts the engine on fast idle.
As for remembering to push in the knob, I suppose that might be a problem, but I drove a Jeep for 10 years with one, my riding lawn mower has one, my 1966 f600 Ford boom truck has one, and I do not have a problem remembering.
Plus, they were standard equipment on cars and trucks for close to 100 years, so it can't be too difficult.
