CallmeKyle
Registered Member
Hey all, I’ve got a 89 k5 Jimmy that needed a radiator. I went ahead and upgraded with a dual electric fan setup. But now that I’m wiring it I’m having trouble finding a good spot to connect for the key-on power to the relay. Is there a wire or place that is easy?. Also do I have to run the power directly from the battery or can I use the fusible link block?
