Electric Fan Realy
riflerk20
Milton, NH
so i just wired up my electric with a new relay and thermostat. the problem is when i put power to the relay the fans come on when the engine is still cool. when i unplug the wire to the thermostat the fans shut off. would a bad thermostat cause this or is it the relay ? Thanks
Fan Switch your calling the "thermostat" right? If it's grounding at a lower temp it's bad.
The fans turn off when the ignition is off right?
