After adding my engine cage I can not fit the windstars anymore(the big motor hits the tube) So I need new fans, trying to decide to go push or pull. Anyone have any opinions on which is better?
just a note..
A mechanical fan usually will always out flow an electric fan
You could always have both push and pull (on separate circuits) one for normal use and the other for extreme use or when in need of more movement..
one on each side....
take note on the fans your cutting up tho.
if the blades were formed to be a puller, then it wont work as good pusher.unless its a straight blade design then it matters not.
I have yet to hear anyone ever say that the windstars did not work.redo the tube so the windstars fitI have yet to hear anyone ever say that the windstars did not work.
rock on. just throwing it out there since sometimes you get caught up in an idea and the little things can slip under the radar til your balls deep. (yah, like that ever happens) sucks bout the dmax.Yah I'm smart enough to figure that one out. The larger diameter windstar will be used in the rear with most likely a custom shroud. Then a small pusher fan for the front. The small 11" pusher fans are cheap and that fits into my budget since I just spent 3 grand on Injectors for my dmax.
i believe i'd heard that before as well but wasnt sure where.According to Ford cooling engineers, a pull style fan is about 10% more efficient than a pusher fan. You can check that out in the May 2012 issue of CarCraft Magazine, page 36.
but the windstar fans are supposed to be great. also made by ford cooling engineers?The only problem with Ford engineers is that the New Explorers, have overheating issues.......There fans are junk...So i dont trust what they say
yup. sometimes the easiest/best answer is the one your trying hard to ignore.They have been great for me like I said, I was just over thinking and trying to reinvent the wheel.
