Put a 240* temp switch in the cold side of the tank and you'll have some serious problems way before the fans kick on. Just using that 240* switch as an example, there are plenty that work at much lower temps I'm sure, just had to mention it though.
Curious why you say it's better on the cool side? I'm sure if you knew the correlation between inlet and outlet temperatures you could use that method, but if you don't know the temp in the heads or intake with the corresponding radiator temp, I don't see how you could know what temp the fans should turn on to prevent overheating in the hottest portions of the engine. Fan's can't cool the radiator below ambient (not even close in use) obviously, but they theoretically can cool it well below engine operating temp.
It's a closed system, so raised temps in one location will reflect everywhere, but 200* on the cool side of the radiator could be 250* at the heads.
I would think it much easier (cheaper) for GM to run a temp probe in the radiator than the intake, but thats how they did it for all vehicles I am aware of...they must have had a reason to do it that way, no?
Pretty sure most of the aftermarket setups take the temp from the radiator, but the only reason I see for that is simplicity...they don't have to worry about fittings between makes and years.
I'm going to have to agree with the airflow statement, the electric fans probably don't impede airflow while turning anymore than when shut off, (because they will "freewheel" if the air pushing on them is greater than the speed they are pulling air in) but running all the time induces more load on the alternator when not required, and if not on some sort of switch, as was mentioned, that can be detrimental to fan and radiator life in water. /forums/images/graemlins/smile.gif
