Extreme_Fabrication
Registered Member
So, we bought my wife a 84 GMC Jimmy. Has a electric fuel pump that is on as soon as you turn key on. I dont like it. I am afraid it is pumping to much fuel to carb. It does have a regulator and gauge, but gauge not working. By looks of it is just a cheapy off the shelf. While it running I can smell the fuel at engine. Motor idles ok, but when you give it throttle, it sounds as if it is loading up.
My question: Do I keep the electric fuel pump or go back to stock style fuel pump? So in future pump isnt pumping to much fuel or run battery down.
What are some you your suggestions or comments on both style fuel pumps?
..I wasted no time moving it away from the exhaust,and tying it up better "for now"...truck isn't on the road and probably wont be any time soon...
