454Sub
5/8 ton status
I have searched and searched for this, i may just not be using the right keyword combo. I have, obviously, a np205 out of an 80 3/4ton. It has a slip yolk output that i would prefer to retain, as i dont really have the extra cash to convert it to a fixed yolk, and then buy the driveshaft on top of it. So i have seen several companies that offer a buffer that screws into the original cable operated case, and then plugs into my factory wiring and working the speedo and all that other stuff. I have never seen a review or anything on them describing how good they work, a part number or if its even a 2 or 4 pulse sensor. I have run the truck for 3 or so years with a 350 without it ever working and it was ok, but i put in a BB a few years ago and its never ran quite right, kinda stumbles as i come off the throttle at real low crawling speed, and the 350 never did this. I know it controls the EGR, idle speeds, and a assortment of other stuff, but the only thing bothering me is this tiny little stumble, and i plan on starting to drive it on the road instead of it rusting up my driveway and would like a speedo just cause. So can anyone give me some insight on one of these contraptions or point me in a direction so i can look?
. I have to install the crossover I have yet to order, a handmade 1/2in zero-rate to move the axle forward for the driveshaft so that i can then measure up and weld me up a square tube driveshaft for the front, put the dash back in for the 500th time I think, put most of the door panels and interior back in it, and figure something out with this speedo gear, and i was just really hoping to not have to drop the t-case. And i have 2 weeks do do all of it, nothing like a little bit of procrastination to spice up your life.
