Other way is to get a multimeter that has the "buzzer" sound for continuity checking. At one end of the wire you put one probe to the wire, then to ground. If the wire is supposed to be a ground, the buzzer will sound. If the wire is NOT supposed to be a ground, and the buzzer sounds, it's shorted somewhere. If the wire checks out ok that way, then you move on to clipping one probe onto one end of the wire, and the other probe to the other end, and making sure the buzzer sounds. If it doesn't, the wire is broken internally.
Broken wires internally though are pretty rare, without either massive corrosion which is usually evident, or severe trauma to the wire, which is also normally evident. I always look very good at the connectors, and make sure the wire ends/terminals are locked into it good. Sometimes if the locks are bad when you plug a connector in, and the lock is bad, it will push the wire out just enough to not make contact, or make a poor contact.
Did this just suddenly crop up out of the blue, or was some re-wiring done to the truck first?
