HighPressure
Newbie
Hi!
I read already a lot of Threads here and via Google and was trying today a lot to check and fix.
I hope someone of you can help me on:
When I turn on the Lights by using the Headlight Knob, my Headlight and my Parking light work, aswell as my taillight. All Position lights / Turn Signals work.
But:
NONE of the Bulbs in the Dash, nor the two who are not directly connected to the cirtuit board light up, only the bulb in the heater / a/c control lights up.
When I push the Break Pedal, the break light does not turn on.
When I pull the washer switch to turn on the high beam, nothing happens.
This one does not give me some click or response, maybe that one is bad?
I read some threads and someone said the only position where all these cables connect is the headlight knob.
So i unscrewed it and disconnected the cable.
I took a multimeter and checked the pins.. that one on the picture has no voltage and the other one 0.30
They are rather rusty.. do you thinkt his could be the reason for this?
the connector that I marked with NO VOLTAGE is a dark brown cable.
One goes into a cable hose and one has a plug-connector which is not connected to anything. this cable is about 15 cm long (6 inch)
the fuses seem to be all ok and strong enough.
further,... my circuit board is very rusty and oxidated.
The Gauges, except the Voltage and the Speedometer do not work. They are not stuck. I can move them by hand
Do you think this comes from the circuit board?
what would I do, except replacing it ?
I live in Europe and its rather hard and expensive to get a fitting swap part
Would be great if someone has any Ideas whats wrong or to tell me how to figure out whats wrong.
Thanks !!
But:
Thanks !!
