Electric Rear Window
FergsK5
Moncks Corner, SC
Anybody have any knowledge of a switch that detects that the tailgate is closed? I've heard rumor that the window will only go up (using the switch) if the tailgate is in the closed position. Mine will not go up at all, only down. I belive, if this switch does exist, that it may have gone bad and could be the problem. Any ideas?
I know there is a switch and I had that problem myself one time the switch was just not triggering at all I gave the tailgate one good closing and never had anymore problems with it at all .....Jason hope that helps
Yes this switch does exist, look inside your tailgate, at either one of the latches, one side will have the switch, just unplug the wire from the switch, cut the plug off, and splice the wires back together. Switch will then be eliminated /forums/images/graemlins/thumb.gif
Well, I found the switch and it was bad. I bypassed it and still no luck. I can;t figure it out. I have another tailgate in perfect condition, and i may just put that on. It is a manual, so i wouldnt have any problems there. I just don't want to have it painted to match, I'd rather be cheap. Anyways, thanks for your help. Any more ideas would be appreciated.
