Electric window question
TACMED
Newbie
Alabama
I have problem with Passenger side window. Have replaced motor(twice) window will only raise from driver door as well as pass egr door. Any suggestions. Thanks for the help
Well, if it works from anywhere, its not the motor. I think you mistyped, but from what I read, it only works from the driver's side.
Sounds like either a bad switch, or a wiring problem. Not sure what type and model truck you have, but on most of them the driver side switch will override the passenger side switch.
So, it could be a bad driver side switch even though that side works.
If its an older vehicle, many of them need a relay mod done. A combination of small factory wire, older switches and old cruddy tracks makes the windows really slow. Lots of folks here add a couple of relays powered directly off the battery with heavier wire to get full voltage to the motor.
Let us know what you got.
