The battery will go dead after a few days, the battery is newish and in good condition, the alternator I have tested and it tests good many times...but I also have tested it and it showed bad twice?
I remove the ground from the battery and with a 12volt test light it will shine brightly, even after half an hour while I made sure the computers where all powered down. I have pulled all the fuses one at a time from both fuse boxes and removed the three fuses from the command start.
There is no other aftermarket accessories on this vehicle.
I don't have a multi meter or do I even know how to use one if it did.
Any ideas on how to find the drain?
