Everything worked fine then all of the sudden I have no dash lights, no tail lights.
When I turn on my headlights the under dash light comes on, when I twist the headlight knob to turn it off the overhead dome light comes on.
I checked all but 1 fuse. There were about 3 fuses burned out so I replaced them but it didn't fix the problem.
I checked the connection at the steering column and it looked good. I unplugged it, inspected it , and plugged it back in.
Still no luck.
Also I installed diodes at the tail lights for flat towing. They have always worked fine.
Still no luck.
classic! I'm sure that was it.
