Well...I was psyched to mud the Blazer, but it appears I have an electrical gremlin. As soon as the key hits the ON position, I pop the gauge fuse.
There is a short to ground somewhere. I've had the dash apart a few times when I installed the clutch pedal, so now it comes apart again. I have an electric meter showing (beeping) continuity between the OUT side of the fuse position, and ground. So I will start pulling screws and wires until I find which one gives the short.
The only things that go out with the fuse are the gauges for volts, temp., and oil pressure.
Anyone have an easier suggestion? I'm not great at searching electric problems, especially under the dash!
