Folks,
I have a 91 Blazer 6.2 ltr and need some help...I decides last month to remove both front fenders to fix some rust stuff and while it was opened up, I decided to replace the upper/lower radiator hose, power steering hoses, thermostat, all wire loom protectors, repaint fenders, and everything else I could. (Battery trays were a mess and power steering connections are tight at the pump). Job went well - used all stainless hardware. Also installed new front grill/cowl.
On the driver side of the engine block directly behind the power steering pump is a green wired connection (2 attached pics). When working on the power steering pump, I removed this connection but whenI did I was at an odd angle and didn't see where the other end came from. Well now a week later with everything ready to re-assemble, I cannot see where the green wire connects to! In the course of re-looming all engine wires i disconnected many wires and never had a problem. I looked from every angle and cannot see where it goes/connects to. The wire exits out of the main wire loom (protecter) which is on the driver side of the engine. It is directly behing the power steering pump. I can't start it because with the fender out, the battery cannot be hooked up.
I have my Haynes Diesel manual but I'm not the greatest on electrical stuff. Any help would be appreciated. Thanks in advance!
