B
bnc04
Guest
Need some electrical diagnosing help
My 88 350 tbi has started doing some strange and inconsistent things.
Voltage drops intermittently- caused by several things like, Running Blower fan, When brakes are hit, When turn signal is activated. When power windows are used. When the radio is on, it will cut out when this happens. It happens when every accessory is off. Radio, Amp, Fan motor, etc . The problem is not constant and at times there is no issue at all. Sometimes while driving, the volts will drop, then recover. Sometimes, They can be raised up again by activating the windows or turn signal or brakes. Sometimes when I try and start the truck, the acc will work ( lights, buzzer etc) in the first position but there is no starting the thing, It is just like a dead battery. If I try it a few times it will eventually “ catch” and fire up.
What I have done.
Replaced break light activation switch.
Cleaned Taillights connection both cable and bulbs.
Run a ground from battery to Body
I’m pretty sure I have a bad ground somewhere but I can’t get a feel for where to look. I’ve done some looking around and can’t see anything obvious.
Do you guys have any suggestions on what to look for and how to look for it?
Isolation techniques?
Thanks in advance,
Brett
What I have done.
Thanks in advance,
Brett
