85chevy1
Registered Member
WEll i managed to fine tune the rear end's issue, but now the front end has just got me stumped.
The singles kinda work and kinda dont.
The lights are suppose to flash one at a time correct? side marker then front, side then front.
the driver's side does this. but then when we go to the passenger side it does not work like this. both bulbs flash at once.
Now this is with the head light switch in the off position.
Once i pull the switch all the way out the pass side doesn't work at all. The signal indicator in the dash stay's solid all the time even when the lights are off.
i have checked grounds. re grounded. checked for short's grounded wire's. I have come to a dead end. replaced the flasher and hat didn't work.
SO does any one have any idea or a clue as to where i should go on with this?
