Muddytazz
1 ton status
Dome light circuit, how does this work. Which wire is hot with the dome light switch off and which is hot with it on. Fighting no dome lights
I'll check the headlight switch though. Even with a dead drivers door switch, I think the domelight still works through the switch.
I checked mine. If your *drivers* door switch is bad, the dome lights won't work even if the headlight switch is fully counterclockwise.. However the floor bulb (above the transmission tunnel under the dash) WILL work with the headlight switch even if the drivers door switch is bad.Still working on the fuel gauge issue, but on the dome light thing. Both my door jamb switches are bad and my dome lights work off the rotation of the headlight switch.
Not sure where you got this idea, but my driver's door switch is bad and my dome lights work throughout.If it's not pegging out the opposite way, you need to start working back towards the gauge. I'd be suspicious of the instrument panel connector.
You beat me to the dome light.I checked mine. If your *drivers* door switch is bad, the dome lights won't work even if the headlight switch is fully counterclockwise.. However the floor bulb (above the transmission tunnel under the dash) WILL work with the headlight switch even if the drivers door switch is bad.
